Next revision | Previous revision | ||
usage:animated [2020/06/14 12:06] – created dushyantvyasg007 | usage:animated [2023/07/09 09:24] (current) – Selecting tools flywire | ||
+ | This tutorial will guide step by step to understand from very basic behavior of tools. In other word, it can be an **Animated User Manual**. | ||
+ | Contents of this Tutorial will follow as mentioned below. | ||
+ | * **Line** | ||
+ | * **Circle** | ||
+ | * **Modify** | ||
- | This tutorial will guide step by step to understand from very basic behavior of tools. In other word, it can be an **Animated User Manual**. | ||
- | In order to see GIF images, image should be open in individual page or new tab and then click the image. | ||
- | Contents of this Tutorial will follow as mentioned below. (Tutorials of remaining tools will be uploaded as soon as it will be ready). | ||
+ | Use the Tools Menu or Toolbar to select tools. | ||
^ Line ^ Circle | ^ Line ^ Circle | ||
Line 21: | Line 48: | ||
Line 34: | Line 61: | ||
- | === 2 POINT === | ||
