usage:animated [2020/06/14 12:50] – dushyantvyasg007 | usage:animated [2020/06/18 05:09] – dushyantvyasg007 | ||
- | In order to see GIF images, image should | + | |
+ | Contents of this Tutorial will follow as mentioned below. | ||
+ | * **Line** | ||
+ | * **Circle** | ||
+ | * **Modify** | ||
- | Contents of this Tutorial will follow as mentioned below. (Tutorials of remaining tools will be uploaded as soon as it will be ready). | ||
- | Before moving to tutorials, one should keep in mind the following things: | ||
- | * Mouse button action. | ||
- | * Right click works as same as ' | ||
Line 26: | Line 42: | ||
Line 39: | Line 55: | ||
- | **Tool** '' | + | |
- | {{ : | + | [[CIRCLE]] |
