usage:animated [2020/06/14 13:49] – dushyantvyasg007 | usage:animated [2020/06/18 05:09] – dushyantvyasg007 | ||
Line 6: | Line 6: | ||
This tutorial will guide step by step to understand from very basic behavior of tools. In other word, it can be an **Animated User Manual**. | This tutorial will guide step by step to understand from very basic behavior of tools. In other word, it can be an **Animated User Manual**. | ||
- | {{ :usage:main_page.gif? |}} | + | |
+ | {{ :usage:main_page02.gif? |}} | ||
Line 12: | Line 13: | ||
* **Circle** | * **Circle** | ||
Line 24: | Line 42: | ||
Line 37: | Line 55: | ||
