usage:animated [2020/06/14 13:10] – dushyantvyasg007 | usage:animated [2023/07/09 09:24] (current) – Selecting tools flywire | ||
- | In order to see GIF images, image should be open in individual page or new tab and then click the image. | + | |
- | Contents of this Tutorial will follow as mentioned below. | + | {{ : |
+ | Contents of this Tutorial will follow as mentioned below. | ||
+ | * **Line** | ||
+ | * **Circle** | ||
+ | * **Modify** | ||
+ | Use the Tools Menu or Toolbar to select tools. | ||
^ Line ^ Circle | ^ Line ^ Circle | ||
Line 23: | Line 48: | ||
Line 36: | Line 61: | ||
- | **Tool** '' | + | |
- | {{ : | + | [[CIRCLE]] |
