usage:animated [2020/06/17 17:38] – dushyantvyasg007 | usage:animated [2023/07/09 09:24] (current) – Selecting tools flywire | ||
+ | Use the Tools Menu or Toolbar to select tools. | ||
^ Line ^ Circle | ^ Line ^ Circle | ||
Line 28: | Line 48: | ||
Line 41: | Line 61: | ||
- | | + | [[LINE]] |
- | | + | [[CIRCLE]] |
