usage:faq [2020/02/09 16:54] – [Printing/exporting issues] fa201 | usage:faq [2020/02/24 04:05] – Managing files on GitHub Link flywire | ||
Line 16: | Line 18: | ||
**Why do I not see the text associated with dimensions? | **Why do I not see the text associated with dimensions? | ||
- | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//. | + | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ |
- | If you see an **empty rectangle** where the tewt dimension should be then check that //View -> Draft// is not active. | + | If you see an **empty rectangle** where the dimension |
**How can I copy a part of a drawing to another drawing? | **How can I copy a part of a drawing to another drawing? | ||
Line 27: | Line 29: | ||
**My drawing had some hatches. How can I see them?**\\ | **My drawing had some hatches. How can I see them?**\\ | ||
If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | ||
+ | ==== Graphical User Interface issues ==== | ||
+ | **Some " | ||
+ | First, determine the type of " | ||
+ | The // | ||
+ | You may refer to the [[https:// | ||
+ | ** Why does the DWG import fail?**\\ | ||
+ | The support of DWG format by LibreCAD is basic. If the DWG import fails, you can convert from DWG to DXF format. Free converters are available on the web. | ||
Line 41: | Line 53: | ||
**How do I print a drawing with dimensions to a specific scale?**\\ | **How do I print a drawing with dimensions to a specific scale?**\\ | ||
Line 48: | Line 61: | ||
+ | **How can I use User Manual Offline?** | ||
+ | **Purpose: | ||
+ | **Install: | ||
+ | * Download https:// | ||
+ | **Run:** | ||
