usage:faq [2020/02/09 17:10] – [GUI issues] fa201 | usage:faq [2020/03/23 21:19] – ODA File Converter flywire | ||
Line 16: | Line 18: | ||
**Why do I not see the text associated with dimensions? | **Why do I not see the text associated with dimensions? | ||
- | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//. | + | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ |
- | If you see an **empty rectangle** where the tewt dimension should be then check that //View -> Draft// is not active. | + | If you see an **empty rectangle** where the dimension |
**How can I copy a part of a drawing to another drawing? | **How can I copy a part of a drawing to another drawing? | ||
Line 34: | Line 36: | ||
The // | The // | ||
You may refer to the [[https:// | You may refer to the [[https:// | ||
- | **The DXF import | + | ** Why does the DWG import |
- | LibreCAD does not support | + | The support of DWG format |
+ | **The DXF import process failed, why?**\\ | ||
+ | LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the [[http:// | ||
+ | **ODA File Converter**\\ | ||
+ | Try [[https:// | ||
Line 47: | Line 54: | ||
**How do I print a drawing with dimensions to a specific scale?**\\ | **How do I print a drawing with dimensions to a specific scale?**\\ | ||
Line 54: | Line 62: | ||
+ | **How can I use User Manual Offline?** | ||
+ | **Purpose: | ||
+ | **Install: | ||
+ | * Download https:// | ||
+ | **Run:** | ||
