usage:faq [2020/02/09 17:23] – [Drawing issues] formatting fa201 | usage:faq [2020/03/23 21:35] – tweak flywire | ||
Line 17: | Line 19: | ||
**Why do I not see the text associated with dimensions? | **Why do I not see the text associated with dimensions? | ||
You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ | ||
- | If you see an **empty rectangle** where the tewt dimension should be then check that //View -> Draft// is not active. | + | If you see an **empty rectangle** where the dimension |
**How can I copy a part of a drawing to another drawing? | **How can I copy a part of a drawing to another drawing? | ||
Line 34: | Line 36: | ||
The // | The // | ||
You may refer to the [[https:// | You may refer to the [[https:// | ||
Line 41: | Line 44: | ||
+ | **ODA File Converter**\\ | ||
+ | Try [[https:// | ||
Line 50: | Line 54: | ||
**How do I print a drawing with dimensions to a specific scale?**\\ | **How do I print a drawing with dimensions to a specific scale?**\\ | ||
Line 57: | Line 62: | ||
+ | **How can I use User Manual Offline?** | ||
+ | **Purpose: | ||
+ | **Install: | ||
+ | * Download https:// | ||
+ | **Run:** | ||
