usage:faq [2020/02/09 17:40] – fixed typo lordofbikes | usage:faq [2020/02/17 04:17] – Simplify flywire | ||
Line 34: | Line 36: | ||
The // | The // | ||
You may refer to the [[https:// | You may refer to the [[https:// | ||
Line 50: | Line 53: | ||
**How do I print a drawing with dimensions to a specific scale?**\\ | **How do I print a drawing with dimensions to a specific scale?**\\ | ||
Line 57: | Line 61: | ||
+ | **How can I use User Manual Offline?** | ||
+ | **Purpose: | ||
+ | **Install: | ||
+ | * Download https:// | ||
+ | **Run:** | ||
+ | This process will only work for one file and you can repeat it for two. Complex Pull Requests involving multiple files should be submitted using Git. |
