usage:faq [2020/02/14 03:31] – Clarify flywire | usage:faq [2020/03/24 06:27] – ODA Online Converter flywire | ||
Line 44: | Line 44: | ||
+ | **Open Design Alliance File Converter**\\ | ||
+ | Try the [[https:// | ||
Line 58: | Line 59: | ||
**Where can I find the upcoming release of LibreCAD? | **Where can I find the upcoming release of LibreCAD? | ||
- | For most OS, it is possible to build the release under development with this [[https:// | ||
For most OS, it is possible to build the release under development with this [[https:// | For most OS, it is possible to build the release under development with this [[https:// | ||
Line 68: | Line 67: | ||
**Purpose: | **Purpose: | ||
- | * Allow Read the Docs files to be hosted locally and viewed | + | * Allow Read the Docs files to be viewed |
* Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | * Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | ||
Line 85: | Line 84: | ||
If you make any changes to the local User Manual files they will be updated in the browser. | If you make any changes to the local User Manual files they will be updated in the browser. | ||
