usage:faq [2020/02/14 03:32] – Remove duplicate flywire | usage:faq [2020/03/23 21:35] – tweak flywire | ||
Line 44: | Line 44: | ||
+ | **ODA File Converter**\\ | ||
+ | Try [[https:// | ||
Line 66: | Line 67: | ||
**Purpose: | **Purpose: | ||
- | * Allow Read the Docs files to be hosted locally and viewed | + | * Allow Read the Docs files to be viewed |
* Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | * Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | ||
Line 83: | Line 84: | ||
If you make any changes to the local User Manual files they will be updated in the browser. | If you make any changes to the local User Manual files they will be updated in the browser. | ||
