usage:faq [2020/01/04 22:03] – Link to library how-to fa201 | usage:faq [2020/04/01 12:44] – Links for FAQs flywire | ||
- | **This section is under work** | ||
====== Frequently Asked Questions ====== | ====== Frequently Asked Questions ====== | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
- | **Is the line width feature broken?**\\ | + | |
+ | === Is the line width feature broken? | ||
You might need to zoom in to see the width or increase the line width. The line width is not shown when Draft Mode is enabled. | You might need to zoom in to see the width or increase the line width. The line width is not shown when Draft Mode is enabled. | ||
- | **Is the unit precision broken? All the lines seem to have the same width.**\\ | + | === Is the unit precision broken? All the lines seem to have the same width. |
If the issue is on the //Status bar// or the information given in the //Command line window// then check //Current Drawing Preferences -> Units//. If the issue affects the dimensions, check //Current Drawing Preferences -> Dimensions// | If the issue is on the //Status bar// or the information given in the //Command line window// then check //Current Drawing Preferences -> Units//. If the issue affects the dimensions, check //Current Drawing Preferences -> Dimensions// | ||
- | **Why do I not see the text associated with dimensions?**\\ | + | === Why do I not see the text associated with dimensions? |
- | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale// | + | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ |
+ | If you see an **empty rectangle** where the dimension text should be, then check that //View -> Draft// is not active. | ||
- | **How can I copy a part of a drawing to another drawing?**\\ | + | === How can I copy a part of a drawing to another drawing? |
See the [[usage: | See the [[usage: | ||
- | **Is there a library of drawing elements?**\\ | + | === Is there a library of drawing elements? |
Yes. There is a [[https:// | Yes. There is a [[https:// | ||
- | **My drawing had some hatches. How can I see them?**\\ | + | === My drawing had some hatches. How can I see them? === |
If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | ||
+ | ==== Graphical User Interface issues ==== | ||
+ | === Some " | ||
+ | First, determine the type of " | ||
+ | The // | ||
+ | You may refer to the [[https:// | ||
- | **The DXF import process failed, why?**\\ | + | === Why does the DWG import fail? === |
- | LibreCAD does not support all features of Autodesk DXF format. Currently only the following DXF formats are supported : R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the [[http:// | + | The support of DWG format by LibreCAD is basic. If the DWG import fails, you can convert from DWG to DXF format. Free converters are available on the web. |
+ | === The DXF import process failed, why? === | ||
+ | LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the [[http:// | ||
+ | === Open Design Alliance File Converter === | ||
+ | Try the [[https:// | ||
- | **Why does exporting a PDF produce a blank page?**\\ | + | |
+ | === Why does exporting a PDF produce a blank page? === | ||
You need to select a paper format (e.g. A4) in //Current Drawing Preferences// | You need to select a paper format (e.g. A4) in //Current Drawing Preferences// | ||
- | **How do I print to a specific scale?**\\ | + | === How do I print a drawing with dimensions |
- | **Where can I find the upcoming release of LibreCAD?**\\ | + | ===Where can I find the upcoming release of LibreCAD?=== |
For most OS, it is possible to build the release under development with this [[https:// | For most OS, it is possible to build the release under development with this [[https:// | ||
+ | === How can I use User Manual Offline? === | ||
+ | **Purpose: | ||
+ | **Install: | ||
+ | * Download https:// | ||
+ | **Run:** | ||
+ | === Can I easily contribute on GitHub? === | ||
