usage:faq [2020/02/17 04:15] – Grammar flywire | usage:faq [2020/03/24 06:27] – ODA Online Converter flywire | ||
Line 44: | Line 44: | ||
+ | **Open Design Alliance File Converter**\\ | ||
+ | Try the [[https:// | ||
Line 66: | Line 67: | ||
**Purpose: | **Purpose: | ||
- | * Allow Read the Docs files to be hosted locally and viewed | + | * Allow Read the Docs files to be viewed |
* Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | * Make edits to the docs themselves and render them locally so you can inspect changes before pushing back to the fork | ||
Line 98: | Line 99: | ||
Each contribution should have its own branch so just start again. If you missed something in the //pull request// just open up your repository fork branch, change it and commit a new change. | Each contribution should have its own branch so just start again. If you missed something in the //pull request// just open up your repository fork branch, change it and commit a new change. | ||
- | This process will only work for one file and you can repeat it for two. Complex Pull Requests involving multiple files should be submitted using Git. | + | This process will only work for one file and you can repeat it for two. Complex Pull Requests involving multiple files should be submitted using Git. |
