usage:faq [2020/03/23 21:34] – Open Design Alliance downloads flywire | usage:faq [2020/04/01 12:44] – Links for FAQs flywire | ||
Line 8: | Line 8: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
+ | **[[usage: | ||
+ | * [[usage: | ||
- | **Is the line width feature broken?**\\ | + | |
+ | === Is the line width feature broken? | ||
You might need to zoom in to see the width or increase the line width. The line width is not shown when Draft Mode is enabled. | You might need to zoom in to see the width or increase the line width. The line width is not shown when Draft Mode is enabled. | ||
- | **Is the unit precision broken? All the lines seem to have the same width.**\\ | + | === Is the unit precision broken? All the lines seem to have the same width. |
If the issue is on the //Status bar// or the information given in the //Command line window// then check //Current Drawing Preferences -> Units//. If the issue affects the dimensions, check //Current Drawing Preferences -> Dimensions// | If the issue is on the //Status bar// or the information given in the //Command line window// then check //Current Drawing Preferences -> Units//. If the issue affects the dimensions, check //Current Drawing Preferences -> Dimensions// | ||
- | **Why do I not see the text associated with dimensions?**\\ | + | === Why do I not see the text associated with dimensions? |
You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ | You might need to raise the value of //Current Drawing Preferences -> Dimensions -> Text Height//. You might also need to adjust the value of //Current Drawing Preferences -> Dimensions -> General Scale//.\\ | ||
If you see an **empty rectangle** where the dimension text should be, then check that //View -> Draft// is not active. | If you see an **empty rectangle** where the dimension text should be, then check that //View -> Draft// is not active. | ||
- | **How can I copy a part of a drawing to another drawing?**\\ | + | === How can I copy a part of a drawing to another drawing? |
See the [[usage: | See the [[usage: | ||
- | **Is there a library of drawing elements?**\\ | + | === Is there a library of drawing elements? |
Yes. There is a [[https:// | Yes. There is a [[https:// | ||
- | **My drawing had some hatches. How can I see them?**\\ | + | === My drawing had some hatches. How can I see them? === |
If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | If //Draft// mode is selected then hatches cannot be seen. Check that //View -> Draft// is not active. | ||
==== Graphical User Interface issues ==== | ==== Graphical User Interface issues ==== | ||
- | **Some " | + | |
+ | === Some " | ||
First, determine the type of " | First, determine the type of " | ||
The // | The // | ||
Line 40: | Line 74: | ||
- | ** Why does the DWG import fail?**\\ | + | === Why does the DWG import fail? === |
The support of DWG format by LibreCAD is basic. If the DWG import fails, you can convert from DWG to DXF format. Free converters are available on the web. | The support of DWG format by LibreCAD is basic. If the DWG import fails, you can convert from DWG to DXF format. Free converters are available on the web. | ||
- | **The DXF import process failed, why?**\\ | + | === The DXF import process failed, why? === |
LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the [[http:// | LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007. If you have issues to import some DXF files, please report them on the [[http:// | ||
- | **ODA File Converter**\\ | + | === Open Design Alliance |
- | Try [[https:// | + | Try the [[https:// |
- | **Why does exporting a PDF produce a blank page?**\\ | + | |
+ | === Why does exporting a PDF produce a blank page? === | ||
You need to select a paper format (e.g. A4) in //Current Drawing Preferences// | You need to select a paper format (e.g. A4) in //Current Drawing Preferences// | ||
- | **How do I print a drawing with dimensions to a specific scale?**\\ | + | === How do I print a drawing with dimensions to a specific scale? |
Line 58: | Line 95: | ||
- | **Where can I find the upcoming release of LibreCAD?**\\ | + | ===Where can I find the upcoming release of LibreCAD?=== |
For most OS, it is possible to build the release under development with this [[https:// | For most OS, it is possible to build the release under development with this [[https:// | ||
Line 64: | Line 101: | ||
==== Host User Manual Locally ==== | ==== Host User Manual Locally ==== | ||
- | **How can I use User Manual Offline?** | + | === How can I use User Manual Offline? |
**Purpose: | **Purpose: | ||
Line 87: | Line 124: | ||
==== Contribute on GitHub ==== | ==== Contribute on GitHub ==== | ||
- | **Can I easily contribute on GitHub?** | + | === Can I easily contribute on GitHub? |
**Yes**, with a simple //pull request//. You will need to register a GitHub account, login then go to the page. For example, click the //Edit on GitHub// link in the top right-hand corner of any User Manual page to go to the page. | **Yes**, with a simple //pull request//. You will need to register a GitHub account, login then go to the page. For example, click the //Edit on GitHub// link in the top right-hand corner of any User Manual page to go to the page. | ||
Line 101: | Line 138: | ||
This process will only work for one file and you can repeat it for two. Complex Pull Requests involving multiple files should be submitted using Git. | This process will only work for one file and you can repeat it for two. Complex Pull Requests involving multiple files should be submitted using Git. | ||
- | [[https:// | + | [[https:// |
