usage:howto [2020/03/30 21:59] – How to add radius circle tangent to two lines flywire | usage:howto [2020/05/02 22:04] – [How to convert from mm to inches ?] dellus | ||
- | ====== How to ====== | + | [[usage: |
The content is the following: | The content is the following: | ||
+ | * [[usage: | ||
===== How to copy entities from drawing A to drawing B? ===== | ===== How to copy entities from drawing A to drawing B? ===== | ||
Line 54: | Line 58: | ||
- Optionally, you can modify the block: look at the [[https:// | - Optionally, you can modify the block: look at the [[https:// | ||
- | Note that other folders are also visible: these are coming by **standard** with the installation of LibreCAD. Your library will be **added** to the standard library. This way, **your library is not deleted when uninstalling | + | Note that other folders are also visible: these are coming by **standard** with the installation of LibreCAD. Your library will be **added** to the standard library. This way, **your library is not deleted when uninstalling |
===== How to add radius circle tangent to two lines ? ===== | ===== How to add radius circle tangent to two lines ? ===== | ||
Line 66: | Line 70: | ||
{{usage: | {{usage: | ||
+ | This is for an intended print scale of 1: | ||
+ | 1. Select all, by command (Tools - Select - Select All), or by pulling up a window around it. | ||
+ | 2. Scale (Tools - Modify - Scale) | ||
+ | 3. Specify reference point, normally best 0,0. Enter. | ||
+ | 4. In the Scaling Options: | ||
+ | 5. Set Main Units: | ||
+ | 6. Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings. | ||
+ | And save it under a new name of course. | ||
