usage:howto [2020/04/01 12:47] – Format flywire | usage:howto [2020/05/02 21:58] – [How to] dellus | ||
- | ====== How to ====== | + | [[usage: |
Line 6: | Line 6: | ||
* [[usage: | * [[usage: | ||
+ | * [[usage: | ||
Line 69: | Line 70: | ||
{{usage: | {{usage: | ||
+ | This is for an intended print scale of 1: | ||
+ | 1. Select all, by command (Tools - Select - Select All), or by pulling up a window around it. | ||
+ | 2. Scale (Tools - Modify - Scale) | ||
+ | 3. Specify reference point, normally best 0,0. Enter. | ||
+ | 4. In the Scaling Options: | ||
+ | 5. Set Main Units: | ||
+ | 6. Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings. | ||
+ | And save it under a new name of course. | ||
