usage:howto [2020/05/02 22:04] – [How to convert from mm to inches ?] dellus | usage:howto [2020/06/26 04:08] – Markup code flywire | ||
Line 28: | Line 28: | ||
Let's say, we want to create a special part as shown below. Note that there are 2 layers, one for the part (yellow) and one for its axis (red). {{usage: | Let's say, we want to create a special part as shown below. Note that there are 2 layers, one for the part (yellow) and one for its axis (red). {{usage: | ||
==== Step 1: create a block ==== | ==== Step 1: create a block ==== | ||
Line 70: | Line 69: | ||
{{usage: | {{usage: | ||
===== How to convert from mm to inches ? ===== | ===== How to convert from mm to inches ? ===== | ||
Line 80: | Line 77: | ||
Then to scale from mm to inches: | Then to scale from mm to inches: | ||
- | 1. Select all, by command (Tools - Select - Select All), or by pulling up a window around it. | + | - Select all, by command (Tools - Select - Select All), or by pulling up a window around it. |
- | 2. Scale (Tools - Modify - Scale) | + | |
- | 3. Specify reference point, normally best 0,0. Enter. | + | |
- | 4. In the Scaling Options: | + | |
To adapt the Drawing Preferences to inches: | To adapt the Drawing Preferences to inches: | ||
- | 5. Set Main Units: | + | - Set Main Units:\\ {{: |
- | 6. Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings. | + | |
- | And save it under a new name of course. | + | |
