Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
usage:howto [2020/06/26 04:08] – Markup code flywire | usage:howto [2020/09/08 21:27] – 'fake' circular dimension jack_sprat | ||
Line 87: | Line 87: | ||
- Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings.\\ {{: | - Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings.\\ {{: | ||
+ | ===== How to ' | ||
+ | In essence, we use one of the existing dimension tools, and then manually edit the label. | ||
+ | This really only works convincingly on segments of circles, although the approach could be applied to a continuous string of line entities, at a push. | ||
+ | **Step-by-step example:** | ||
+ | - draw a circle, centred on a grid point (**Circle: Center, Point** tool) | ||
+ | - draw two lines, from centre to perimeter, to define a segment (**Line: 2 Points** tool) | ||
+ | - divide the circle at the two lines, to create an arc (two, actually) (Modify: Divide tool) | ||
+ | - select the arc to find its length in the status bar | ||
+ | - create an angular dimension annotation between the two lines (**Dimension: | ||
+ | - edit the dimension properties, defining a new label with the length of the arc (**Modify: Properties** tool) | ||
+ | **Hint:** you can find the centre of an arc with the **Dimension: | ||
