usage:howto [2020/01/24 19:35] – Remove under work notice flywire | usage:howto [2020/09/08 21:30] – [How to] jack_sprat | ||
+ | [[usage: | ||
====== How to ====== | ====== How to ====== | ||
The content is the following: | The content is the following: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
+ | * [[usage: | ||
===== How to copy entities from drawing A to drawing B? ===== | ===== How to copy entities from drawing A to drawing B? ===== | ||
Line 23: | Line 30: | ||
Let's say, we want to create a special part as shown below. Note that there are 2 layers, one for the part (yellow) and one for its axis (red). {{usage: | Let's say, we want to create a special part as shown below. Note that there are 2 layers, one for the part (yellow) and one for its axis (red). {{usage: | ||
==== Step 1: create a block ==== | ==== Step 1: create a block ==== | ||
Line 53: | Line 59: | ||
- Optionally, you can modify the block: look at the [[https:// | - Optionally, you can modify the block: look at the [[https:// | ||
- | Note that other folders are also visible: these are coming by **standard** with the installation of LibreCAD. Your library will be **added** to the standard library. This way, **your library is not deleted when uninstalling | + | Note that other folders are also visible: these are coming by **standard** with the installation of LibreCAD. Your library will be **added** to the standard library. This way, **your library is not deleted when uninstalling |
+ | ===== How to add radius circle tangent to two lines ? ===== | ||
+ | - draw two crossing lines | ||
+ | - create a construction layer | ||
+ | - On the construction layer, draw a fillet with the required radius (shown dashed in image so visible) | ||
+ | - On the drawing layer, draw a circle with the " | ||
+ | The lines and circle will be perfectly tangent, for instance the " | ||
+ | {{usage: | ||
+ | This is for an intended print scale of 1:1. | ||
+ | - Select all, by command (Tools - Select - Select All), or by pulling up a window around it. | ||
+ | - Scale (Tools - Modify - Scale) | ||
+ | - Specify reference point, normally best 0,0. Enter. | ||
+ | - In the Scaling Options:\\ {{: | ||
+ | - Set Main Units:\\ {{: | ||
+ | - Adapt Dimensions. You could do it with General Scale 1/25.4, but better let it at 1 for possible later print scaling and change the size values individually. You can later use these settings for all your inches drawings.\\ {{: | ||
+ | ===== How to ' | ||
+ | In essence, we use one of the existing dimension tools, and then manually edit the label. | ||
+ | This really only works convincingly on segments of circles, although the approach could be applied to a continuous string of line entities, at a push. | ||
+ | **Step-by-step example: | ||
+ | - draw a circle, centred on a grid point (**Circle: Center, Point** tool) | ||
+ | - draw two lines, from centre to perimeter, to define a segment (**Line: 2 Points** tool) | ||
+ | - divide the circle at the two lines, to create an arc (two, actually) (Modify: Divide tool) | ||
+ | - select the arc to find its length in the status bar | ||
+ | - create an angular dimension annotation between the two lines (**Dimension: | ||
+ | - edit the dimension properties, defining a new label with the length of the arc (**Modify: Properties** tool) | ||
+ | **Hint:** you can find the centre of an arc with the **Dimension: | ||
