usage:line [2020/06/17 17:37] – created dushyantvyasg007 | usage:line [2020/06/18 06:49] – dushyantvyasg007 | ||
+ | ==== LINE: 2 Points ==== | ||
+ | * specify **first point** (left-click). | ||
+ | * specify the First point (left-click). | ||
+ | * **@50< | ||
+ | * **@50,50** for Square or **@50,30** for Rectangle. | ||
+ | * **@60< | ||
+ | ==== LINE: Angle ==== | ||
+ | ==== LINE: Horizontal ==== | ||
+ | ==== LINE: Vertical ==== | ||
+ | ==== LINE: Rectangle ==== | ||
+ | ==== LINE: Parallel through point ==== | ||
+ | ==== LINE: Parallel ==== | ||
+ | ==== LINE: Bisector ==== | ||
+ | ==== LINE: Tangent (P,C) ==== | ||
+ | ==== LINE: Tangent (C,C) ==== | ||
+ | ==== LINE: Tangent Orthogonal ==== | ||
+ | ==== LINE: Orthogonal ==== | ||
+ | ==== LINE: Relative Angle ==== | ||
+ | ==== LINE: Polygon [(Cen,Cor), (Cen,Tan), (Cor,Cor)] ==== | ||
