usage:line [2020/06/17 17:37] – dushyantvyasg007 | usage:line [2020/06/18 06:49] – dushyantvyasg007 | ||
- | === LINE: 2 Points === | + | ==== LINE: 2 Points ==== |
+ | * specify **first point** (left-click). | ||
+ | * specify the First point (left-click). | ||
+ | * **@50< | ||
+ | * **@50,50** for Square or **@50,30** for Rectangle. | ||
+ | * **@60< | ||
+ | ==== LINE: Angle ==== | ||
