usage:line [2020/06/18 03:43] – dushyantvyasg007 | usage:line [2020/06/18 07:21] – dushyantvyasg007 | ||
- | * type ' | + | |
Line 14: | Line 13: | ||
+ | * specify the First point (left-click). | ||
+ | * **@50< | ||
+ | * **@50,50** for Square or **@50,30** for Rectangle. | ||
+ | * **@60< | ||
- | {{: | + | ==== LINE: Angle ==== |
