usage:line [2020/06/18 03:57] – dushyantvyasg007 | usage:line [2020/06/18 06:59] – dushyantvyasg007 | ||
- | * type ' | + | |
Line 18: | Line 17: | ||
- | * **@60<120 or @60 < -120** for **60mm line at 120 degree**. (try {-}(minus) symbol before ' | + | * **@60< |
