usage:line [2020/06/18 04:28] – dushyantvyasg007 | usage:line [2020/06/18 06:46] – dushyantvyasg007 | ||
- | * type ' | + | |
Line 18: | Line 17: | ||
- | * **@60< | + | * **@60< |
- | * specify | + | * enter **angle** (see 'tool option' |
+ | * specify | ||
=== LINE: Horizontal === | === LINE: Horizontal === | ||
- | === LINE: Tangent Orthogonal === | + | ==== LINE: Tangent Orthogonal |
