usage:line [2020/06/18 04:31] – dushyantvyasg007 | usage:line [2020/06/18 06:59] – dushyantvyasg007 | ||
- | * type ' | + | |
Line 18: | Line 17: | ||
- | * **@60< | + | * **@60< |
- | * enter **angle** (see 'tool option' | + | * enter **angle** (see 'tool option' |
- | * enter **length**. | + | * enter **length** |
