usage:line [2020/06/18 05:46] – dushyantvyasg007 | usage:line [2020/06/18 06:09] – dushyantvyasg007 | ||
==== LINE: 2 Points ==== | ==== LINE: 2 Points ==== | ||
Line 26: | Line 25: | ||
* enter **angle** (see 'tool option' | * enter **angle** (see 'tool option' | ||
- | * specify **start, middle, or end** __snap__ __point__ | + | * specify **start, middle**, or **end** __snap__ __point__ |
Line 45: | Line 44: | ||
==== LINE: Rectangle ==== | ==== LINE: Rectangle ==== | ||
==== LINE: Parallel through point ==== | ==== LINE: Parallel through point ==== | ||
==== LINE: Parallel ==== | ==== LINE: Parallel ==== | ||
