usage:line [2020/06/18 05:45] – dushyantvyasg007 | usage:line [2020/06/18 07:21] – dushyantvyasg007 | ||
Line 22: | Line 21: | ||
* enter **angle** (see 'tool option' | * enter **angle** (see 'tool option' | ||
- | * specify **start, middle, or end** __snap__ __point__ | + | * specify **start, middle**, or **end** __snap__ __point__ |
- | === LINE: Vertical === | + | ==== LINE: Vertical |
