usage:line [2020/06/18 05:46] – dushyantvyasg007 | usage:line [2020/06/18 07:21] – dushyantvyasg007 | ||
==== LINE: 2 Points ==== | ==== LINE: 2 Points ==== | ||
Line 26: | Line 25: | ||
* enter **angle** (see 'tool option' | * enter **angle** (see 'tool option' | ||
- | * specify **start, middle, or end** __snap__ __point__ | + | * specify **start, middle**, or **end** __snap__ __point__ |
Line 41: | Line 44: | ||
==== LINE: Rectangle ==== | ==== LINE: Rectangle ==== | ||
==== LINE: Parallel through point ==== | ==== LINE: Parallel through point ==== | ||
==== LINE: Parallel ==== | ==== LINE: Parallel ==== | ||
==== LINE: Bisector ==== | ==== LINE: Bisector ==== | ||
==== LINE: Tangent (P,C) ==== | ==== LINE: Tangent (P,C) ==== | ||
==== LINE: Tangent (C,C) ==== | ==== LINE: Tangent (C,C) ==== | ||
==== LINE: Tangent Orthogonal ==== | ==== LINE: Tangent Orthogonal ==== | ||
==== LINE: Orthogonal ==== | ==== LINE: Orthogonal ==== | ||
==== LINE: Relative Angle ==== | ==== LINE: Relative Angle ==== | ||
