usage:line [2020/06/18 05:52] – dushyantvyasg007 | usage:line [2020/06/18 07:25] – dushyantvyasg007 | ||
Line 4: | Line 4: | ||
==== LINE: 2 Points ==== | ==== LINE: 2 Points ==== | ||
Line 26: | Line 26: | ||
Line 40: | Line 44: | ||
==== LINE: Rectangle ==== | ==== LINE: Rectangle ==== | ||
==== LINE: Parallel through point ==== | ==== LINE: Parallel through point ==== | ||
==== LINE: Parallel ==== | ==== LINE: Parallel ==== | ||
==== LINE: Bisector ==== | ==== LINE: Bisector ==== | ||
==== LINE: Tangent (P,C) ==== | ==== LINE: Tangent (P,C) ==== | ||
==== LINE: Tangent (C,C) ==== | ==== LINE: Tangent (C,C) ==== | ||
==== LINE: Tangent Orthogonal ==== | ==== LINE: Tangent Orthogonal ==== | ||
==== LINE: Orthogonal ==== | ==== LINE: Orthogonal ==== | ||
==== LINE: Relative Angle ==== | ==== LINE: Relative Angle ==== | ||
