usage:line [2020/06/18 06:40] – dushyantvyasg007 | usage:line [2020/06/18 07:25] – dushyantvyasg007 | ||
Line 26: | Line 26: | ||
Line 40: | Line 44: | ||
Line 78: | Line 84: | ||
==== LINE: Tangent (P,C) ==== | ==== LINE: Tangent (P,C) ==== | ||
==== LINE: Tangent (C,C) ==== | ==== LINE: Tangent (C,C) ==== | ||
==== LINE: Tangent Orthogonal ==== | ==== LINE: Tangent Orthogonal ==== | ||
==== LINE: Orthogonal ==== | ==== LINE: Orthogonal ==== | ||
==== LINE: Relative Angle ==== | ==== LINE: Relative Angle ==== | ||
