usage:line [2020/06/18 06:59] – dushyantvyasg007 | usage:line [2020/06/18 07:25] – dushyantvyasg007 | ||
Line 27: | Line 27: | ||
* specify **position** | * specify **position** | ||
Line 36: | Line 36: | ||
Line 45: | Line 45: | ||
Line 110: | Line 110: | ||
==== LINE: Orthogonal ==== | ==== LINE: Orthogonal ==== | ||
Line 115: | Line 118: | ||
==== LINE: Relative Angle ==== | ==== LINE: Relative Angle ==== | ||
- | * click the {{: | + | * click the {{: |
- | * click the {{: | + | |
- | * click the {{: | + | * specify **center** |
- | * enter **number** of sides as required | + | * specify **corner** |
- | * specify **first corner** | + | |
- | * specify **second corner** | + | |
* **Right-click** to ' | * **Right-click** to ' | ||
