usage:manuals [2020/01/09 20:44] – [Older releases of User Manual] gsster | usage:manuals [2020/02/12 03:52] – Tidy link descriptions flywire | ||
- | **This section is under work** | + | ====== Documentation ====== |
- | ====== LibreCAD Documentation ====== | + | The documentation |
- | All the help files and support | + | |
- | ===== How the documentation is organized ? ===== | + | |
- | LibreCAD | + | |
- | The User Manual is hosted at //Read the Docs// whereas the [[usage:tutorials|tutorials]] and [[usage:howto|how-to]] are available on this //DokuWiki//. | + | |
===== LibreCAD User Manual ===== | ===== LibreCAD User Manual ===== | ||
- | The [[https:// | + | The [[https:// |
+ | The manual | ||
* **Installation** instructions including //building from source// and configuration of LibreCAD. | * **Installation** instructions including //building from source// and configuration of LibreCAD. | ||
* **Reference** section describing the commands and their parameters. | * **Reference** section describing the commands and their parameters. | ||
* **User guides** providing steps to perform common tasks. | * **User guides** providing steps to perform common tasks. | ||
- | It is the primary source of documentation. | ||
===== Other User Manuals ===== | ===== Other User Manuals ===== | ||
- | Other manuals are available: | ||
- | * https:// | ||
- | * http:// | ||
Note that these manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | Note that these manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | ||
- | You may find older documentations | + | ==v2.2== |
+ | * [[https:// | ||
+ | ==v2.1== | ||
+ | ==v2.0== | ||
+ | ==v1.0== | ||
