usage:manuals [2020/01/09 20:42] – [LibreCAD User Manual] gsster | usage:manuals [2020/02/12 04:06] – Old manual warning flywire | ||
- | **This section is under work** | + | ====== Documentation ====== |
- | ====== | + | The documentation is only available on the web. It consists of the [[https:// |
- | All the help files and support documentation are only available on the web. | + | ===== LibreCAD User Manual ===== |
- | ===== How the documentation is organized ? ===== | + | **:!: LibreCAD v2.2.x User Manual, DRAFT** |
- | LibreCAD team moved the documentation from previous Wiki to **Read the Docs** (RtD) and to **DokuWiki**. | + | >**This is the initial DRAFT of the LibreCAD User Manual |
+ | >**The manual is based on LibreCAD v2.2.0rc1. If you are using another version of LibreCAD, your mileage may vary.** | ||
- | The User Manual is hosted at //Read the Docs// whereas the [[usage: | + | ---- |
- | ===== LibreCAD User Manual ===== | + | The [[https:// |
- | The [[https:// | + | The manual |
* **Installation** instructions including //building from source// and configuration of LibreCAD. | * **Installation** instructions including //building from source// and configuration of LibreCAD. | ||
* **Reference** section describing the commands and their parameters. | * **Reference** section describing the commands and their parameters. | ||
* **User guides** providing steps to perform common tasks. | * **User guides** providing steps to perform common tasks. | ||
- | It is the primary source of documentation. | ||
- | ===== Older releases of User Manual | + | ===== Other User Manuals |
+ | ===v2.2 - Current and complete=== | ||
+ | * [[https:// | ||
+ | :!: Note: These manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | ||
+ | ==v2.1== | ||
- | You may find older documentations for version 1.0 and 2.0 along with some French and Spanish documents on the [[https:// | + | ==v2.0== |
+ | ==v1.0== | ||
+ | * [[https:// |
