usage:manuals [2020/01/17 10:30] – Grammar, consistent terminology flywire | usage:manuals [2020/02/13 00:25] – Old manual warning flywire | ||
- | **This section is under work** | + | ====== Documentation ====== |
- | ====== | + | The documentation is only available on the web. It consists of the [[https:// |
- | All the help files and support documentation are only available on the web. | + | ===== LibreCAD User Manual ===== |
- | ===== How the documentation is organized ? ===== | + | **:!: LibreCAD v2.2.x User Manual, DRAFT** |
- | The [[https:// | + | > |
+ | >**The manual is based on LibreCAD v2.2.0rc1. If you are using another version of LibreCAD, your mileage may vary.** | ||
- | ===== LibreCAD User Manual ===== | + | ---- |
- | The [[https:// | + | The [[https:// |
+ | The manual | ||
* **Installation** instructions including //building from source// and configuration of LibreCAD. | * **Installation** instructions including //building from source// and configuration of LibreCAD. | ||
* **Reference** section describing the commands and their parameters. | * **Reference** section describing the commands and their parameters. | ||
* **User guides** providing steps to perform common tasks. | * **User guides** providing steps to perform common tasks. | ||
- | It is the primary source of documentation. | ||
===== Other User Manuals ===== | ===== Other User Manuals ===== | ||
- | Other manual: | + | ===v2.2 - Current and complete=== |
- | * http://www.heikell.fi/ | + | |
+ | * [[https:// | ||
+ | :!: Note: These manuals are for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | ||
- | Note that these manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | + | ==v2.1== |
- | You may find older documentation for version 1.0 and 2.0, and some French and Spanish documents, in the [[https:// | + | ==v2.0== |
+ | ==v1.0== | ||
+ | * [[https:// |
