usage:manuals [2020/01/18 20:12] – Add links flywire | usage:manuals [2020/02/12 04:06] – Old manual warning flywire | ||
- | **This section is under work** | ||
====== Documentation ====== | ====== Documentation ====== | ||
Line 7: | Line 5: | ||
===== LibreCAD User Manual ===== | ===== LibreCAD User Manual ===== | ||
- | The [[https:// | + | **:!: LibreCAD v2.2.x User Manual, DRAFT** |
+ | >**This is the initial DRAFT of the LibreCAD User Manual and is subject to change.** | ||
+ | >**The manual is based on LibreCAD v2.2.0rc1. If you are using another version of LibreCAD, your mileage may vary.** | ||
+ | The [[https:// | ||
+ | The manual | ||
* **Installation** instructions including //building from source// and configuration of LibreCAD. | * **Installation** instructions including //building from source// and configuration of LibreCAD. | ||
* **Reference** section describing the commands and their parameters. | * **Reference** section describing the commands and their parameters. | ||
* **User guides** providing steps to perform common tasks. | * **User guides** providing steps to perform common tasks. | ||
- | The [[https:// | ||
===== Other User Manuals ===== | ===== Other User Manuals ===== | ||
- | Other manual: | + | ===v2.2 - Current and complete=== |
- | * http://www.heikell.fi/ | + | |
+ | * [[https:// | ||
+ | :!: Note: These manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | ||
- | Note that these manuals may be for older versions of LibreCAD and may not reflect the command or layout found in the latest release of LibreCAD. | + | ==v2.1== |
- | You may find older documentation for version 1.0 and 2.0, and some French and Spanish documents, in the [[https:// | + | ==v2.0== |
+ | ==v1.0== | ||
+ | * [[https:// |
