community:contribute_code [2020/01/19 11:27] – SourceForge nightly builds flywire | community:contribute_code [2023/02/07 21:09] (current) – fixed IRC link to libera.chat lordofbikes | ||
- | **This section is under work** | ||
====== Write code ====== | ====== Write code ====== | ||
Line 13: | Line 11: | ||
* Autodesk DXF format | * Autodesk DXF format | ||
- | If you are a developer, outstanding in C++, or a beginner we can use all the help. With a bit of determination, | + | If you are a developer, outstanding in C++, or a beginner we can use all the help. With a bit of determination, |
A good starting point for developers is the LibreCAD [[https:// | A good starting point for developers is the LibreCAD [[https:// | ||
Git and Github usage and LibreCAD font format. | Git and Github usage and LibreCAD font format. |
