tutorial:carport
tutorial:carport [2020/06/25 03:42] – Created flywiretutorial:carport [2020/06/26 04:12] (current) – Markup code for images in lists flywire
Line 21: Line 21:
   -Start LibreCAD -    -Start LibreCAD -
   -Check your version via the Help/About menu item - the example here have been created with version 2.1.3   -Check your version via the Help/About menu item - the example here have been created with version 2.1.3
-  -First you might want to decide about your application preferences using [[LibreCAD_Quick_Start_Guide/Customizing_LibreCAD#Appearance|Options/Application Preferences/Appearance]] (in Version 2.0.9 Edit/Application Preferences) +  -First you might want to decide about your application preferences using [[LibreCAD_Quick_Start_Guide/Customizing_LibreCAD#Appearance|Options/Application Preferences/Appearance]]
-    -For this example the background color has been changed to "white"+
   -Save the default "unnamed document 1" as "CarportEast" using the "File/Save" Menu   -Save the default "unnamed document 1" as "CarportEast" using the "File/Save" Menu
   -Check that the save was successful by Quitting LibreCAD, and restarting it. The saved file "CarportEast.dxf" should show up in the "File/Recent Files" Menu   -Check that the save was successful by Quitting LibreCAD, and restarting it. The saved file "CarportEast.dxf" should show up in the "File/Recent Files" Menu
Line 39: Line 38:
 The first lines of any technical drawing are the ''construction lines'', setting out the locations of all lines without specifying any line types, colours, etc. All straight construction lines are of 'infinite' length — i.e. they extend off the screen in both directions. The first lines of any technical drawing are the ''construction lines'', setting out the locations of all lines without specifying any line types, colours, etc. All straight construction lines are of 'infinite' length — i.e. they extend off the screen in both directions.
-  -Create a new [[Layers#Construction_Layers|Construction layer]] by clicking the "+" sign in the Layer list. The new layer might have a name such as 'construction', and a colour of magenta or cyan or similar. The line's width should be '0'. +  -Create a new [[Layers#Construction_Layers|Construction layer]] by clicking the "+" sign in the Layer list. The new layer might have a name such as 'construction', and a colour of magenta or cyan or similar. The line's width should be '0'.\\ {{tutorials:carport:Construtionlayerdialogexample.jpg|}}
-{{tutorials:carport:Construtionlayerdialogexample.jpg|}} +
   -Make sure ''[[Snapping|Snap]] on grid'' is enabled.   -Make sure ''[[Snapping|Snap]] on grid'' is enabled.
Line 197: Line 193:
   -select the default layer again   -select the default layer again
-  -select the polyline tool +  -select the polyline tool\\ {{tutorials:carport:Polylinetoolselection.jpg|}}
-{{tutorials:carport:Polylinetoolselection.jpg|}}+
   -for each of the three beam polylines you need to    -for each of the three beam polylines you need to
     -click four times at the positions to get three sides of the beam outline     -click four times at the positions to get three sides of the beam outline
tutorial/carport.1593056566.txt.gz · Last modified: 2020/06/25 03:42 by flywire
