Trace: • simple_template
tutorial:simple_template
tutorial:simple_template [2020/02/11 13:15] – Simple Template created flywiretutorial:simple_template [2020/03/15 22:13] (current) – Fix link flywire
 ==== Simple Template ==== ==== Simple Template ====
-One of the benefits of a template is they guide the user laying out the drawing and, if no entities are placed outside the template, the drawing will be centered on the sheet when printing. This tutorial will create a minimalist A4 landscape template with a thin border 5mm inside the edge of the page.+One of the benefits of a template is they guide the user laying out the drawing and, if no entities are placed outside the template, the drawing will be centred on the sheet when printing. This tutorial is for metric units and will create a minimalist A4 landscape template with a border on the edge of the page, the unprintable area of most printers.
-Simply stated, templates are nothing more than a simple drawing file that especially contains various settings and components that can be used repetitively. These settings can be as simple as the paper definition and unit specifications but can include layers, block devices and drawing elements like any other drawing. These settings are however limited to the drawing only. Template drawings are unable to alter application preferences or other global settings within LibreCAD. The User Manual [[https://librecad.readthedocs.io/en/latest/index.html#templates|templates]] has more detail.+Templates are nothing more than a simple drawing file that contains various settings and components that can be used repetitively. These settings are limited to the drawing only and will not alter application preferences or other global settings within LibreCAD. The User Manual [[https://librecad.readthedocs.io/en/latest/guides/dwg-setup.html#templates|templates]] has more detail.
-Check Current [[https://librecad.readthedocs.io/en/latest/ref/draw-prefs.html|Drawing Preferences]], Paper Format is set to A4 Landscape. Check the [[https://librecad.readthedocs.io/en/latest/ref/widgets.html#layer-list-dock|Layer Settings]] are: Layer Name: 0, Construction Layer: clear, Color: Black / White, Width: 0.25mm, Line type: continuous.+Check:
 +  * [[https://librecad.readthedocs.io/en/latest/ref/draw-prefs.html|Drawing Preferences]] settings - Paper: A4, Landscape, Units: Millimeter.
 +  * [[https://librecad.readthedocs.io/en/latest/ref/widgets.html#layer-list-dock|Layer Settings]] - Layer Name: 0, Construction Layer: clear, Color: Black / White, Width: 0.00mm, Line type: continuous.
 Use the [[https://librecad.readthedocs.io/en/latest/guides/cmdline.html|Command Line]] widget to enter the following commands: Use the [[https://librecad.readthedocs.io/en/latest/guides/cmdline.html|Command Line]] widget to enter the following commands:
 <code>rec <code>rec
 0,0 0,0
-287,200+297,210
 za za
 k k
 </code> </code>
-Be aware that some printers will not print 5mm off a margin. You may also prefer to use a more complex template from another tutorial, perhaps one with a title block.+The page border will be displayed in the Drawing Window. Check it and save it with the following commands: File, Print Preview, set scale to 1:1, click "Center to page" icon and tick fixed to lock the scale.
 +File, Save as A4-Landscape-Template.dxf in the template directory (refer [[https://librecad.readthedocs.io/en/latest/guides/dwg-setup.html#default-templates|default templates]]). File, Close.
-File, Print Preview, set scale to 1:1, centre page with mouse and tick fixed. +Test the template is working as expected: File, New From Template, Select A4-Landscape-Template.dxf then File, Print Preview. Click "Center to page" icon if required.
-File, Save as A4-Landscape-Template.dxf in the template directory (refer [[https://librecad.readthedocs.io/en/latest/guides/drawingsetup.html#default-templates|default templates]]).+
-File, Close then File, New From Template, Select A4-Landscape-Template.dxf then File, Print Preview to check template.+Check the other tutorials for a more complex template with a border and title block.
tutorial/simple_template.1581426921.txt.gz · Last modified: 2020/02/11 13:15 by flywire
