usage:line [2020/06/18 05:38] – dushyantvyasg007 | usage:line [2020/06/18 06:09] – dushyantvyasg007 | ||
Line 22: | Line 21: | ||
- | * enter **angle** (see 'tool option' | + | * enter **angle** (see 'tool option' |
- | * enter **length**. | + | * enter **length** |
=== LINE: Horizontal === | === LINE: Horizontal === | ||
- | * | + | * enter **length** |
- | === LINE: Bisector === | + | ==== LINE: Bisector |
- | === LINE: Tangent Orthogonal === | + | ==== LINE: Tangent Orthogonal |
