usage:line [2020/06/18 05:38] – dushyantvyasg007 | usage:line [2020/06/18 07:25] – dushyantvyasg007 | ||
Line 22: | Line 21: | ||
- | * enter **angle** (see 'tool option' | + | * enter **angle** (see 'tool option' |
- | * enter **length**. | + | * enter **length** |
- | * | + | * enter **length** |
