usage:line [2020/06/18 05:40] – dushyantvyasg007 | usage:line [2020/06/18 07:31] (current) – dushyantvyasg007 | ||
- | * click the {{: | + | ==== LINE: 2 Points |
- | * specify first point (left-click). | + | * click the {{: |
- | * Right-click to ' | + | * specify |
Line 22: | Line 20: | ||
* enter **angle** (see 'tool option' | * enter **angle** (see 'tool option' | ||
- | * specify **start, middle, or end** snap point | + | * specify **start, middle**, or **end** __snap__ __point__ |
