usage:line [2020/06/18 06:59] – dushyantvyasg007 | usage:line [2020/06/18 07:31] (current) – dushyantvyasg007 | ||
==== LINE: 2 Points ==== | ==== LINE: 2 Points ==== | ||
- | * click the {{: | + | * click the {{: |
- | * specify **first point** (left-click). | + | * specify **first point** (left-click) |
* specify **second point** | * specify **second point** | ||
* **Right-click** to ' | * **Right-click** to ' | ||
Line 110: | Line 109: | ||
==== LINE: Orthogonal ==== | ==== LINE: Orthogonal ==== | ||
Line 115: | Line 117: | ||
==== LINE: Relative Angle ==== | ==== LINE: Relative Angle ==== | ||
- | * click the {{: | + | |
- | * click the {{:usage:polygon_cen_cor_.png?|}} icon | + | * specify **center** |
- | * enter **number** of sides as required | + | * specify **corner** |
- | * specify **first corner** | + | |
- | * specify **second corner** | + | |
