Trace: • start • offset • copy • polyline • mirror • singlelinetext • circle
usage:line
usage:line [2020/06/18 03:58] – dushyantvyasg007usage:line [2020/06/18 07:31] (current) – dushyantvyasg007
 ============= LINE ============== ============= LINE ==============
-===== Tool: LINE =====
-=== LINE: 2 Points ===
-{{:usage:2_points.png?|}}
-  * specify the First point (left-click).
-  * specify the Second point (move cursor and left-click).
-  * right-click to 'back' (Escape once) or right-click Two times to 'exit'.
-    * type 'C' and enter to close the path (must be 3 lines/entities at least).
 +==== LINE: 2 Points ====
 +  * click the {{:usage:2_points.png?|}} icon
 +  * specify **first point** (left-click)
 +  * specify **second point**
 +  * **Right-click** to 'back' or press 'Esc' to exit.
 {{ :usage:00-2_points.gif?}}   {{ :usage:00-2_points.gif?}}
Line 18: Line 16:
   * **@50<0** for straight line.   * **@50<0** for straight line.
   * **@50,50** for Square or **@50,30** for Rectangle.   * **@50,50** for Square or **@50,30** for Rectangle.
-  * **@60<120 for 60mm line at 120 degrees. (try {-}(minus) symbol before 'degree' and see what happen!!)+  * **@60<120** for 60mm line at 120 degrees. (try {-} (minus) symbol before 'degree' and see what happen!!)
-=== LINE: Angle === +==== LINE: Angle ====
-{{:usage:angle.png?|}}+  * click the {{:usage:angle.png?|}} icon
 +  * enter **angle** (see 'tool option')
 +  * enter **length**
 +  * specify **start, middle**, or **end** __snap__ __point__
 +    * specify **position**
 {{ :usage:02-angle.gif? |}} {{ :usage:02-angle.gif? |}}
-=== LINE: Horizontal ===+==== LINE: Horizontal ====
 +  * click the {{:usage:horizontal.png?|}} icon
 {{ :usage:03-horizontal.gif? |}} {{ :usage:03-horizontal.gif? |}}
-=== LINE: Vertical ===+==== LINE: Vertical ====
 +  * click the {{:usage:vertical.png?|}} icon
 {{ :usage:04-vertical.gif? |}} {{ :usage:04-vertical.gif? |}}
-=== LINE: Rectangle ===+==== LINE: Rectangle ====
 +  * click the {{:usage:rectangle.png?|}} icon
 +  * specify **first corner**
 +  * specify **second corner**
 {{ :usage:05-rectangle.gif? |}} {{ :usage:05-rectangle.gif? |}}
-=== LINE: Parallel through point ===+==== LINE: Parallel through point ====
 +  * click the {{:usage:parallel_through_point.png?|}} icon
 +  * select **entity**
 +  * specify through **point** (click at specific point or anywhere to repeat the process)
 {{ :usage:06-parallel_through_point.gif? |}} {{ :usage:06-parallel_through_point.gif? |}}
-=== LINE: Parallel ===+==== LINE: Parallel ====
 +  * click the {{:usage:parallel.png?|}} icon
 +  * enter the **distance** and **number** of copies required OR
 +    * select **entities** and repeat it as required
 {{ :usage:07-parallel.gif? |}} {{ :usage:07-parallel.gif? |}}
-=== LINE: Bisector ===+==== LINE: Bisector ====
 +  * click the {{:usage:bisector.png?|}} icon
 +  * enter **length** and **number** (from tool option)
 +    * select **first line**
 +    * select **second line**
 {{ :usage:08-bisector.gif? |}} {{ :usage:08-bisector.gif? |}}
-=== LINE: Tangent (P,C) ===+==== LINE: Tangent (P,C) ====
 +  * click the {{:usage:tangent_p_c_.png?|}} icon
 +  * specify **point**
 +  * select **circle, arc or ellipse**
 {{ :usage:09-tangent_pc.gif? |}} {{ :usage:09-tangent_pc.gif? |}}
-=== LINE: Tangent (C,C) ===+==== LINE: Tangent (C,C) ====
 +  * click the {{:usage:tangent_c_c_.png?|}}
 +  * select **first circle or ellipse**
 +  * select **second circle or ellipse**
 {{ :usage:10-tangent_cc.gif? |}} {{ :usage:10-tangent_cc.gif? |}}
-=== LINE: Tangent Orthogonal ===+==== LINE: Tangent Orthogonal ====
 +  * click the {{:usage:tangent_orthogonal.png?|}} icon
 +  * select a **line**
 {{ :usage:11-orthogonal_tangent.gif? |}} {{ :usage:11-orthogonal_tangent.gif? |}}
-=== LINE: Orthogonal ===+==== LINE: Orthogonal ====
 +  * click the {{:usage:orthogonal.png?|}} icon
 +  * select **line**
 {{ :usage:12-orthogonal.gif? |}} {{ :usage:12-orthogonal.gif? |}}
-=== LINE: Relative Angle ===+==== LINE: Relative Angle ====
 +  * click the {{:usage:relative_angle.png?|}} icon
 +  * enter **angle** and **length**
 +    * select **base entity**
 +    * select **position**
 {{ :usage:13-relative_angle.gif? |}} {{ :usage:13-relative_angle.gif? |}}
-=== LINE: Polygon [(Cen,Cor), (Cen,Tan), (Cor,Cor)] ===+==== LINE: Polygon [(Cen,Cor), (Cen,Tan), (Cor,Cor)] ====
 +  * click the {{:usage:polygon_cen_cor_.png?|}} icon
 +    * enter **number** of sides as required
 +      * specify **center**
 +      * specify **corner**
 +  * click the {{:usage:polygon_cen_tan_.png?|}} icon
 +      * specify **tangent**
 +  * click the {{:usage:polygon_cor_cor_.png?|}} icon
 {{ :usage:14-all_polygon.gif? |}} {{ :usage:14-all_polygon.gif? |}}
usage/line.1592452736.txt.gz · Last modified: 2020/06/18 03:58 by dushyantvyasg007
