Trace: • start • offset • copy • polyline • mirror • singlelinetext • circle • line
usage:line
usage:line [2020/06/18 05:40] – dushyantvyasg007usage:line [2020/06/18 07:31] (current) – dushyantvyasg007
 ============= LINE ============== ============= LINE ==============
-===== Tool: LINE =====
-=== LINE: 2 Points ===  +
-  * click the {{:usage:2_points.png?|}} icon. +==== LINE: 2 Points ====
-  * specify first point (left-click). +  * click the {{:usage:2_points.png?|}} icon
-  * specify second point +  * specify **first point** (left-click)
-  * Right-click to 'back' or press 'Esc' to exit.+  * specify **second point**
 +  * **Right-click** to 'back' or press 'Esc' to exit.
 {{ :usage:00-2_points.gif?}}   {{ :usage:00-2_points.gif?}}
Line 22: Line 20:
-=== LINE: Angle ===+==== LINE: Angle ====
   * click the {{:usage:angle.png?|}} icon   * click the {{:usage:angle.png?|}} icon
   * enter **angle** (see 'tool option')   * enter **angle** (see 'tool option')
   * enter **length**   * enter **length**
-  * specify **start, middle, or end** snap point+  * specify **start, middle**, or **end** __snap__ __point__
 +    * specify **position**
 {{ :usage:02-angle.gif? |}} {{ :usage:02-angle.gif? |}}
-=== LINE: Horizontal ===+==== LINE: Horizontal ====
   * click the {{:usage:horizontal.png?|}} icon   * click the {{:usage:horizontal.png?|}} icon
 {{ :usage:03-horizontal.gif? |}} {{ :usage:03-horizontal.gif? |}}
-=== LINE: Vertical ===+==== LINE: Vertical ====
 +  * click the {{:usage:vertical.png?|}} icon
 +  * enter **length**
 {{ :usage:04-vertical.gif? |}} {{ :usage:04-vertical.gif? |}}
-=== LINE: Rectangle ===+==== LINE: Rectangle ====
 +  * click the {{:usage:rectangle.png?|}} icon
 +  * specify **first corner**
 +  * specify **second corner**
 {{ :usage:05-rectangle.gif? |}} {{ :usage:05-rectangle.gif? |}}
-=== LINE: Parallel through point ===+==== LINE: Parallel through point ====
 +  * click the {{:usage:parallel_through_point.png?|}} icon
 +  * select **entity**
 +  * specify through **point** (click at specific point or anywhere to repeat the process)
 {{ :usage:06-parallel_through_point.gif? |}} {{ :usage:06-parallel_through_point.gif? |}}
-=== LINE: Parallel ===+==== LINE: Parallel ====
 +  * click the {{:usage:parallel.png?|}} icon
 +  * enter the **distance** and **number** of copies required OR
 +    * select **entities** and repeat it as required
 {{ :usage:07-parallel.gif? |}} {{ :usage:07-parallel.gif? |}}
-=== LINE: Bisector ===+==== LINE: Bisector ====
 +  * click the {{:usage:bisector.png?|}} icon
 +  * enter **length** and **number** (from tool option)
 +    * select **first line**
 +    * select **second line**
 {{ :usage:08-bisector.gif? |}} {{ :usage:08-bisector.gif? |}}
-=== LINE: Tangent (P,C) ===+==== LINE: Tangent (P,C) ====
 +  * click the {{:usage:tangent_p_c_.png?|}} icon
 +  * specify **point**
 +  * select **circle, arc or ellipse**
 {{ :usage:09-tangent_pc.gif? |}} {{ :usage:09-tangent_pc.gif? |}}
-=== LINE: Tangent (C,C) ===+==== LINE: Tangent (C,C) ====
 +  * click the {{:usage:tangent_c_c_.png?|}}
 +  * select **first circle or ellipse**
 +  * select **second circle or ellipse**
 {{ :usage:10-tangent_cc.gif? |}} {{ :usage:10-tangent_cc.gif? |}}
-=== LINE: Tangent Orthogonal ===+==== LINE: Tangent Orthogonal ====
 +  * click the {{:usage:tangent_orthogonal.png?|}} icon
 +  * select a **line**
 {{ :usage:11-orthogonal_tangent.gif? |}} {{ :usage:11-orthogonal_tangent.gif? |}}
-=== LINE: Orthogonal ===+==== LINE: Orthogonal ====
 +  * click the {{:usage:orthogonal.png?|}} icon
 +  * select **line**
 {{ :usage:12-orthogonal.gif? |}} {{ :usage:12-orthogonal.gif? |}}
-=== LINE: Relative Angle ===+==== LINE: Relative Angle ====
 +  * click the {{:usage:relative_angle.png?|}} icon
 +  * enter **angle** and **length**
 +    * select **base entity**
 +    * select **position**
 {{ :usage:13-relative_angle.gif? |}} {{ :usage:13-relative_angle.gif? |}}
-=== LINE: Polygon [(Cen,Cor), (Cen,Tan), (Cor,Cor)] ===+==== LINE: Polygon [(Cen,Cor), (Cen,Tan), (Cor,Cor)] ====
 +  * click the {{:usage:polygon_cen_cor_.png?|}} icon
 +    * enter **number** of sides as required
 +      * specify **center**
 +      * specify **corner**
 +  * click the {{:usage:polygon_cen_tan_.png?|}} icon
 +      * specify **tangent**
 +  * click the {{:usage:polygon_cor_cor_.png?|}} icon
 {{ :usage:14-all_polygon.gif? |}} {{ :usage:14-all_polygon.gif? |}}
usage/line.1592458859.txt.gz · Last modified: 2020/06/18 05:40 by dushyantvyasg007
